This is an example of BMW R1200GS Rear wheel drive. The same as the one I have been given to fix at work.. However, the roll pin you can see is snapped off flush with the casing. It is a 2mm hardened roll pin inside another sleeve. The pin is harder than a HSS drill bit.
I have tried cobalts but they break too.
I have heated it but no joy.
I have tried to anneal the pin before drilling but no joy..
This pin needs to be removed to change the bearing that it holds in place. It is another case of BMW RETARDED engineering which is oh so common.
Our manuals say "Remove roll pin"... Wow, helpful.
I have not drill the other side and I can not drill sideways. I am not allowed.
ANY IDEAS ????????????????? £1200 to replace the case
Thanks in advance.
Ted
Thanks in advance.
Ted
