They are good, I had to fix a screen to a ceramic tiled wall in a new shopping centre restaurant. When I saw where they wanted it I refused to drill the tiles thinking the worst, anyhow the site manager told me to mark it out and one of the lads would drill the holes. Bloke turns up with a Dewalt combi drill and a set of Bosh multi construction bits, five minutes later the job was done with no broken tiles.Look like the Bosch multi construction bits.
They are good, I had to fix a screen to a ceramic tiled wall in a new shopping centre restaurant. When I saw where they wanted it I refused to drill the tiles thinking the worst, anyhow the site manager told me to mark it out and one of the lads would drill the holes. Bloke turns up with a Dewalt combi drill and a set of Bosh multi construction bits, five minutes later the job was done with no broken tiles.I said at the time that I must get a set of them, I never did.
ive allways drilled tiles with a masonry bit and turn off the hammer
I use the bosch multidrills mainly the 6.0mm ones there realy good but some tiles they wont touch. porcelain quarry tiles are a bummerThey are good, I had to fix a screen to a ceramic tiled wall in a new shopping centre restaurant. When I saw where they wanted it I refused to drill the tiles thinking the worst, anyhow the site manager told me to mark it out and one of the lads would drill the holes. Bloke turns up with a Dewalt combi drill and a set of Bosh multi construction bits, five minutes later the job was done with no broken tiles.I said at the time that I must get a set of them, I never did.
What I am prepared to do at home and doing something that has not been allowed for at work is totally different especially when it involves 1200x600 ceramic tiles in a building that is going to open in the next couple of days. I was not going to risk braking one and having to pay to replace it.ive allways drilled tiles with a masonry bit and turn off the hammer
the multidrills have a conventional cutting edge for drilling steel and masonary rather than an impact rotary chiselling effect , before mine get 2 blunt I re sharpen them with a green grinding wheelYou could probably grind a conventional cutting edge on a masonry bit, no idea what kind of wheel you would need, green grit or diamond?
