I got it off, friction was the culprit as suspected earlier. Tightening my homemade puller and then tapping is what did it, refused to budge until I tightened it real hard, then tapped the rod with the hammer, then it moved a little bit. I repeated this for 5 minutes and it was off.
If youve gone to that trouble fit new bearings
Are you absolutely sure the problem is the spindle bearings? Many a home hachinist has encountered a machining problem their slightly more experienced buddies diagnose as "bearings" when the actual problem ("chatter" is a common one) is due to poor work or tool support, tool design, slow feed or a variety of other causes having simple remedies.
I've opened spindle cartridges and head stocks that have been in daily service in heavy industry for 50 years. The reason for entering the spindle was a broken shifter, fix a wobbly control, re-key a control lever etc. The opportunty for examining the spindle bearings and other internal parts is a rare one and they were inspected as a matter of course to the extent possible without actually disassembly. While the spindle preload may have relaxed a trifle and the visible part of the bearing races show indentations from particles in the lubricating oil the bearings still turned round and true and a listening ear on a stethoscope could detect no more than a whisper of a whir when the spindle ran at top speed.
Spindle bearings do fail in service and have to be replaced. My question is why are failed spindle bearings so frequent a diagnosis among home shop machinists compared to industry experience as a whole? Are spindle bearings getting a bum rap? Sometimes I wonder.
Machine tools spindles are traditionally so robust and over-designed they never fail from long service of heavy loads and frequent shock. If they do fail it's from rust, dirt, or a mechanical disaster sufficient to damage most components engaged in the driving train as well.
Finally there is failure mode. Rolling element bearings seldom fail in a way that causes radial or axial clearance except in extremis. The normal falure mode is race fatigue where repeated passing of loaded rolling elements cause fatigue which progress into micorcracks that merge to from spalls that leave behind pits. Spall succeeds spall propogating into a continuous track of spalling onm the races. It's at this point that bearing noise becomes audible over the normal idle machine sounds as a rumble or rattle. Preload may not be affected.
Loss of preload is not evidence of bearing falure. It's evidence of failure of the preload lock nut, axial shifting of bearings not tightly shouldered, incorrect ntal preload setting, deformation of mechanical parts. etc.
Don't really know how one prevents this in the future, thought I had it tight.I tried running it for a minute or so at high speed but it didn't feel any warmer
or you mean the saddle is moving away? Is there a clamp screw on it to lock it off, or do you lock it off with the gearbox?
