Bill Edwards
- Scarborough, North Yorkshire
I would never have thought a 3/8 hose would run a 1" gun I use at least 1/2 on my 3/4snap on
I was surprised at how it managed, it certainly wasn't what I wanted but it was all I had available and I wanted to see if the gun would be worth having with my limited setup, I certainly wasn't disappointed! I'd go with a 1/2 line (think that's what the instructions say it should have) when installing a setup for big guns as I don't doubt it'll get more out of the gun but right now I'm stuck with 3/8 and yet to find a seized or tight nut it's struggled with.
Also the start point of 120 is pretty useless when the pressors diff is 2bar so the tank is at 90ish to begin with, you end up running off air to get down to the switch on point,because at the gun you would be lucky to achieve 60psi, so to then try to undo a tight nut again and with a big tank, that could be 3-5mins ish before pressure is achieved.
Yes the start point is too low really so yes you do sometimes run it off to make it kick in for when you want it, but there's no doubt that the guns have adequate power off that compressor until it's at its lowest. It's getting changed to a bigger compressor when possible but I'd not rush to say 120 won't work a gun because it can.
Pumping up tyres taking ages at the higher level of pressure - oh yes...
