That's 'cos you were too busy drooling over it.I'm waiting for your 'look at what I bought today' post to appear.
Don't know how much you can take on a Friday afternoon mat so here's just a little one 60mm jawsView attachment 60660
This thread is almost making me feel bad for what I'm gonna do to a bloody swivel vice I have kicking about. That thing has taken my knuckles, knees and shins so many times it's now going to meet a plasma cutter.
It's currently buried in a pile whilst I'm refurbishing my shed. Once it comes out I'll photo it for you. It's nothing special but is almost definitely not a Chinese import. It came from a joiner's mate who was selling his stuff for his wife as he'd died. This was ~15 years ago and it wasn't anywhere near new then. Jaws are about four inch and set up for metal not wood.Don't you dare. (There's no harsh glare smiley, so you get a grin instead). Photo's? I'll try my damnedest to find a home for summat rather than it meeting the bin/skip, if it ain't just some modern cheap Chinese affair.
If it turns out to be any use then it's yours Matt.
I can't stand the thing as it's bitten me so many times because it slips.
Not a problem. As much as I hate it I don't really want to kill it. Every time I look at it it makes me angry though!Cheers.![]()
When I got it I thought it was amazing because I rent so don't have any shed/workshop space (have since moved several times). I used it on the kitchen bench and I can still feel the pain from when it rotated as I was filing something and my knuckles ploughed into the bench top.Most swivels seem as if they were designed by Satan himself, don't they.
That's why none of mine, barring the York's, are swivels, and they'll only get used for relatively light duty work because of it. Going flat on my **** when spragged against a bench pulling on something in a swivel vice has always been a vision in my mind.
Swivels are very useful for certain tasks though. It's the old scenario of using everything within its limitations.
I never thought there would be so much interest in vices. wish I knew earlier matt I've just got rid of two Leinens and a record 114 all too big for me
yes I like the ones with the sliding rear jaw. hard to say why really but once you've got one the others seem loose and rattle about. when you wind a record in all the front moves from side to side. the dovetail slides are nice and smooth with little or no play. are you ready for another or have you had enough for one day? what do you think to the little fella?If I seem to be a while before posting again, it's just 'cos I'm sobbing away in a dark corner somewhere.Usually the case, isn't it. It's like when someone tells you they skipped something you've been after for ages, a week or two after they skipped it. Usually slightly too late to the ball.
Is most of your collection of European/German origin? Sounds like you definitely have a preference for them over the English style.
I got a lovely big Record from cumbriasteve and when the shed it done it will have pride of place. It's desperate for a new paint job hence my asking about various finishes.
The idea of being able to touch up where needed is very appealing. Any particular brands to look out for or avoid? I see plastikiote spray enamel is pretty common and comes in nice bright colours.Finish wise, depends what you're after. Powder coat is tough stuff, but like Atconut says, it does chip if you tey hard enough. The problem with powder coat is when it comes to touching up. There's not really any decent way to do it other than coating afresh.
Enamel is fairly robust once it has cured for a few weeks, but will chip/scratch same as owt else. It's a lot easier to touch up though, if you feel the urge. The main point to remember with enamel is that it will be somewhat soft for the first month or so though, so to treat it kindly within that time.
Personally, I go with the enamel. Easily done by yourself instead of relying on someone else, and easily touched up if needs be, and it is quite strudy once fully cured. Powder coat is obviously tougher though. Enamel is easier to remove, if you get the urge to strip it again in the future. They each have their plus and minus points.
I'm in no rush. I've never had a good vice my entire life (well, not one that holds metal wellrustolium combi colours don't know if I've spelled it right very good tough paint but as matt says enamel takes a few weeks to fully harden
Yeah but do they do it in a lurid pink? The rustoleum stuff comes in a nice bright red (RAL3020) which is close enough for me. Rough bits? It'll match its user thenthing is if it's a record it will be a rather rough casting so if you paint it with smooth paint it will show all the rough bits. better off with hammerite on castings
