So, looking at the design of the original unit, If i perform this mod, what regulates the wire feed speed when the power is changed?
i.e before, the voltage to the motor would have been governed by whichever tap was used from the main transformer but now we are just using a straight 24v...
I can't see anything on the PCB that regulates the speed once it is tuned on.
I think I can cope with the transformer spec - if you want to drive a maybe 2 amp 24V motor you'd be looking at a 100VA transformer - and seems the 2*12V thing can be wired for 24V output.
How do you spec a bridge rectifier though? All sorts of massive currents and voltages in the specs - are those maximums and all of them will work perfectly well at the low volts and currents that interest me, or should I be more picky?
Finally, for a bonus point, is there anything available off the shelf that would smooth the output voltage from the transformer? ie give you a constant 15V when the output is varying around 15V in time? I guess a big capacitor would be a starting point, but I'm sure there must be ready built things that are cleverer than I am.
Rectifier ratings are maximum. Bridge rectifiers are cheap enough, go for one twice the rating you need.
You can get voltage regulators, I'm sure there is a fixed 15v one available, just make sure it can handle the current, and that you mount it correctly.
Sure there must be something ready made but I'm not sure what to look for.
No, something that plugs into the output of the transformer that takes in that really spiky stuff at anywhere between 12V and 14V that goes to the torch while you are welding, and outputs the same voltage only smoothed.
Just thinking about something that was mentioned elsewhere about losing the change in wire speed with power setting - wondering if there was some other method of smoothing the motor supply while retaialing that characteristic.
Yes, i see that in the original designThe "power" switch supplies a voltage to the motor circuit depending on the tap selected. In addition the speed knob controls the current running through the motor. I.E. the switch sets the speed in the ball-park, the speed knob fine tunes it..
Err, i don't see how it is doing PWM all of a sudden when the original was not. It's just a power transistor...The straight 24v supplied by the mod. is switched on and off by the PWM circuit, at zero speed it is off all the time, at max speed it is on all the time, and half speed it switches on and off in equal parts, many times a second, and so on for all speeds
No probs... You had me second guessing myself then tho...My mistake - I was confusing this thread with another one suggesting a PWM alternative for the existing linear one!
Circuit board pics here
Last time I asked a welder supplier to advise me on where to put the live and neutral he said it didn't matter. I made my own mind up. On that basis I don't think you could argue a difference.
Though which side of a 240V AC circuit is more deadly when swallowed and why? (Serious question here - I'm coming from the starting point of one being as bad as the other).
