I did consider going this way, and I still would, the only thing that put me off was the unreliability of these PSU's, my laptop has gone through about 4 in the last 18 months, they seem to be all cheap chinese units that just burn out.Following on from ^^^ that post ^^^ I actually used a 21VDC 4A (~90 watt) Dell docking station power supply. If you have an IT department, go scrounge around them as, like us, they probably have a ton of these taking up space in a cupboard.
I place the PSU on the bottom tray, between the fan and the welding transformer (mine is a topmig, with quite a lot of space on the floor). I'm sure I have some pics lying around somewhere...
Edit: Found them!
This is the laptop docking station PSU, mounted between the fan and the welding trannie.
This is the relay, mounted on the floor.
I was thinking the transformer I linked to says it has two outputs so I was hoping it could supply 24v, think I might ring maplins and ask them to recommend the right one, if you define the search for transformers by 24v output, only one shows up which is a big white plastic cased thing which doesn't look like the right thing at all.
...Having any transformer powering on and off I can understand being a bad idea, I thought the chassis mounted types were a bit more sturdy. Would the best option be a chassis mounted transformer and a bridge all running permanent live, and then into a relay to switch on and off?
...Anyway, I appreciate your input, and I can see how it's simpler to install a cased psu, I don't have any contact with tech people at work so would have to buy one. I don't mind the extra wiring if it's cheaper to install a chassis mount one, what would you recommend?
Matt
Yes indeedy
I bought one of these; http://www.maplin.co.uk/p/round-base-10a-relay-240v-ac-3pdt-jg64u
and one of these; http://www.maplin.co.uk/p/round-base-10a240v-ac-dpdt-relay-jg60q
