Hi - my first post on the forum - been reading through many threads with great interest.
Anyway I've an old style SIP 'IDEAL' 120 machine (cira 1982) cracking little welder - however not been used for many years and just started to do some welding with it - new wire/shroud/tip - wire feed motor good (industrial type etc) – new bottle of argoshield - obvious checks on basic electrics and connections etc.
From cold the welder strikes a crisp arc and sounds exactly as it should – the weld pool is good and generally and excellent slug of weld – however the symptoms are progressive as the welder rises in temperature before the thermal cuts in and shuts it down. So what happens after about 3 minutes of welding (without changing any settings) is the current fluctuates/pulses – it’s almost like when you set the wire speed too high – once this happens then it will not weld consistently but if you turn it off and let it cool for 10 minutes – again it work well for 3 – 5 minutes before it starts again.
Also if you touch the ‘job’ with the wire without pulling the trigger then it creates a small arc
So my question is – could this be a capacitor breaking down – a transformer – anyone any ideas?
Thanks and look forward to your assistance
Regards
Mark
Regards
Mark
