sardine
- Buckinghamshire
SIP Medusa T3001GX390
Sorry i meant the motor, honda GX270/390 or Loncin copySIP Medusa T3001
Chinese copySorry i meant the motor, honda GX270/390 or Loncin copy![]()
Or a gaztubeYou ought do a proper, readily findable write-up on that process, for those of us with crappy memories.![]()
Just got one similar myself, really pleased with it although filthy and covered in all the usual detritus. Anyway its been cleaned and partly reassembled but I am in a slight quandary over the starter switch. It still has the original Startet switch, complete with asbestos insulation. Now would it be advisable to replace this with a modern switch, or can I use the original. It’s not going to be used in an industrial setting, nor is it likely to be left in the event of a power failure. Any help, advice or guidance gratefully accepted.Start of a journey.
Old Tauco, (Delta) drill.
Clock spring refitted the correct way round. How the previous owner didn't notice I'll never know.
Before
After
It retracts!
The drill will probably come apart in future, but at least I know this bit can be corrected. Kept me out of mischief for the evening.
Hi Steve,Just got one similar myself, really pleased with it although filthy and covered in all the usual detritus. Anyway its been cleaned and partly reassembled but I am in a slight quandary over the starter switch. It still has the original Startet switch, complete with asbestos insulation. Now would it be advisable to replace this with a modern switch, or can I use the original. It’s not going to be used in an industrial setting, nor is it likely to be left in the event of a power failure. Any help, advice or guidance gratefully accepted.
View attachment 402982 View attachment 402983
and ive run out of gas FFSThat just means it's beer o'clock, and you've earned it.and ive run out of gas FFS
Anyway, before gluing them up properly I sent her this:
That prilla looks like its had a hard life under its skirtA week wouldn't be complete without a carb job, GSXR 750 WP this time, full carb rebuild kit/ clean and setup. Customer came back in today to thank me as he's owned it a fair while and it's never run as good which was nice!.
View attachment 403227View attachment 403228
Aprilia Tuono V4 valve service, front head was great, rear was completely out clearance wise, had to order the factory tooling to remove the cams.
Honda CBR1000RA in for ABS fault. What a convoluted system the C-ABS is, 22 page manual on how to bleed it!. At least they didn't mount the front ABS pump unit 10mm behind a raging hot exhaust manifold, never seen anything as stupid.. No wonder they all go wrong.
