GX390Oops, my generator threw a wobbler.
No other damage luckily, it should be an easy repair .
We did the bottom seal on the VW LT35 the small pipe on the plastic housing broke off so i drilled a hole in what was left then used super glue to fix in a bit of 8mm copper pipe and added some baking soda and glue as a shoulder to help it. View attachment 402385View attachment 402386
I would have done but i could not find an olive, i have also used a yorkshire coupler if itas a bad fitHello, I've done similar repairs on my DS, I always solder an olive near the end of the copper pipe to stop the hose popping off.
Looks as new again, nice.A long day! Bearing replacement and shaft repair on a piece of bakery equipment
View attachment 402528 View attachment 402529 View attachment 402530 View attachment 402531 View attachment 402532 View attachment 402533
Kapton tape on the live centre to stop powder sticking.Looks as new again, nice.
What's with the tape on the center? And inside the centerhole is black tape?
SIP Medusa T3001GX390
Sorry i meant the motor, honda GX270/390 or Loncin copySIP Medusa T3001
Chinese copySorry i meant the motor, honda GX270/390 or Loncin copy
Or a gaztubeYou ought do a proper, readily findable write-up on that process, for those of us with crappy memories.
Just got one similar myself, really pleased with it although filthy and covered in all the usual detritus. Anyway its been cleaned and partly reassembled but I am in a slight quandary over the starter switch. It still has the original Startet switch, complete with asbestos insulation. Now would it be advisable to replace this with a modern switch, or can I use the original. It’s not going to be used in an industrial setting, nor is it likely to be left in the event of a power failure. Any help, advice or guidance gratefully accepted.Start of a journey.
Old Tauco, (Delta) drill.
Clock spring refitted the correct way round. How the previous owner didn't notice I'll never know.
Before
After
It retracts!
The drill will probably come apart in future, but at least I know this bit can be corrected. Kept me out of mischief for the evening.
