Bullet2012
- 238 855 miles from the moon
Dear Mr TYA
Please fix the focusing on your camera.
Thank You
Thank You
For high ceilings you can't beat having the simple slide in /out ceiling roseThe wife bought a strange light fitting for our bedroom about 20 years ago. It has 7 bendy arms with G4 bulbs at the end. Originally it came with halogens, but about 5 or 1p years later replaced them with LEDs. But there was a snag, the 12v driver didn't fire up until you hit 20W, as many halogen transformers do. So I left one halogen in to take it over the 20W until I got around to replacing the driver.
So about 10 or 15 years later, I decided to fix it. I knew it was dim and occasionally flickering because of the temporaey bodge.
I couldn't find a circular driver over 15W. With 7 x 2W LEDs, that's a bit close to the limit so I opted for a none circular 20W driver. I would have gone a bit higher but then it wouldn't have fitted in the base.
After trimming off some excess plastic, it fits in the base, just. I gave it a good clean and test on the kitchen table as our bedroom ceiling is really high, I had to get the scaffy tower out to get to it.
I'm a couple of LEDs short, I thought I had plenty but they turned out to be the old Halogens that I put back in the old LED boxes years ago doh!
But it's a lot brighter now and doesn't flicker. When i bought some more LEDs, I noticed quite a lot of reviews mention they don't work or flicker, I wonder how many are using Halogen drivers.....
They look tasteful….For high ceilings you can't beat having the simple slide in /out ceiling rose View attachment 473880
Gorilla glue is handy stuff....did an internal one recently in a similar way but I had to dowel it as it was a modern door so basically as thick as a tooth picknot gonna say I'm proud of it, but it will do for now until I can take the three doors off and properly re-work the whole thing.
They're all held together with Gorilla Glue as it is, no point using PVA in an exposed exterior door, although the wedged M&T joints probably didn't need it... So it seemed like the obvious choice for a repair.Gorilla glue is handy stuff....did an internal one recently in a similar way but I had to dowel it as it was a modern door so basically as thick as a tooth pick
Gorrilla glue is a good choice for this type of fix....reckon you could just deep drill and dowel the main hinge screws and it would be totally fine.If I have a weekend to get at it I think taking that door off and routing out the damage and gluing in a new section of wood would be best.
Fixed, maybe not but made them a bit better. I find the writing on black sockets hard to see at times
Chrome sockets I can read fairly easily, it’s these black ones I struggle with. I used a paint pen and quick wipe over with a paper towel with a squirt of carb cleaner on it wipe of the excess paintI find the writing on pretty much all sockets is all but invisible in the lighting I've got in my shed. Some of it is the fault of the lighting, and some of it is because my near vision isn't as good as it used to be, but I've marked some of mine with a white marker that I bought and has come it quite useful, more useful than my white paint pen.
