Fixings above the light switch?Coat rack finished, apart from making 20 odd hooks, that’s the last time I’ll see it now.
Spot the mistake?
Water turtle is dead so I've made a funeral ,dig a hole ,put her in a improvised coffin and buried
Battery boxWhat is it?
Spot the mistake?
Good effort, I bet the cost of material was similar to buying ones off the shelfWhile messing about with melter I did a round tuit on lathe and made up 6 pins for dinse 10-25 plugs to be brazed on. Then stuck the 3 I can find with silver solder.
I dont have any original 10-25's so not sure what size the pin should be turned to, 4 or 5mm square is probably ok.
One legged races?I only ever see single shoes at the side of the road.
Don't weld it on with the magnet in placeNow that the crap weather has passed I was able to do a bit. Got the shoots done. Made a start on the handles.
View attachment 334330 View attachment 334331 View attachment 334332
Magnet is just to hold it in place so I can step back to get a visual. Everything is done by hand. All I use is a 0.8 cutting disc. Flap wheel and files.Don't weld it on with the magnet in placeare all the chamfers done by hand? The way everything lines up next to that g clamp is almost pornographic
