pressbrake1
- Essex
Dont let Greta see it!! might need some diagonals on the back to stop it folding up though?
I'd put some slats across the middle too, so you could alternate which side you were using and have one side drying and one side ready. Just a thought!
It's also screwed to the fence posts so fairly stable.Dont let Greta see it!! might need some diagonals on the back to stop it folding up though?
Telescopic bottle car jack .I have failed.....
Confession time. I finished the splitter and went to test it with a bit of properly season wood, using both my drill and impact driver as the motive power. Got about 1.5" in and the jack buckled where I've shown in red in the following pic.
Wedge then turned sideways a good bit and looking at it, the jack isn't up to the joband I'm just going to 'rescue' the bits of pipe and scrap the rest. Not going to attempt any 'rebuild'/redesign. Cost me only the MIG wire, gas and time so no great loss. A bit disappointed to be honest, but Hey...Ho
I never got around to screwing these to the wall, because I couldn't decide where best to put it, it needs to be over a bench but preferably away from grinding dust, then I got distracted and left it somewhere safe until I needed it again. Today I bored the blocks out a bit bigger and split them to clamp onto a bit of stainless pipe which happened to be a nice sliding fit on the Olympus shaft, then screwed the whole thing to my desk.Cut some blocks of horrible plastic (Seem to have broken my circular saw doing so!) and squared them up in the lathe.
Add some lightness at the horizontal boring machine
(Big hole was done in the lathe).
Done, wall mounts for the ZEIlympus microscope project. I'll glue some m8 stud into the brickwork and get it mounted above the bench s
Dig transportation cratesNice work what are they?
They're around 2-3mm away from it it's quite solid I suppose time will tell, first time working on a radiator of any sort rivnuts would be my last worry some of the welds are really bad, I'll not name the company there's welds on top of welds so obviously found a leak or 2are you not worried those riv nuts will vibrate/bump against the radiator core?
Really nice workWas lazy and didn't mitre the tops.
May I ask what sliding door gear you are using?Got runners up today +1 door frame made, will make second next week & start cladding View attachment 359485View attachment 359486
