Pete.
- Kent, UK
Are any of them date stamped? I often used to put at least the year of manufacture on bits that I made.
2001, but I think there might be some 2002 as well.
Looks like matt crinkle powder coat tbhYou can kind of see the texture in this pic, skid plate and crash bars are the same. It is a very fine texture.
Don't think it is powder coat as it was very easy to buff off with a flap disc for welding, any powder coat I have tried that with tends to smear and melt. Also when I welded on the brackets it didn't melt and bubble like I would expect powder coat to do, it just sort of burnt like paint would.Looks like matt crinkle powder coat tbh
Looks like an ih 12/1455?
I liked except for the lightsBleeding farmers around here working at night and close to roads need to adjust their work lights properly
The ones around here can probably do the same, they just don't bother. Often they are still on when they are on the road going to/from fields.The leds have some range, the side mounted ones have limited adjustment, but I can switch each side individually if along side a road.
What do you use for the 45's a tenon saw or a pull saw & mitre block or a sliding chisel guillotine as like a picture framer usesA simple box made out of a lump of Alder I couldn't resist when I visited Wentwood timber.
I had a silly moment and cut the end off one of the sides where the lid slides in, so I made the other one match. I think it would look better with continuous sides but I can't do anything about that now. The lid is also a bit looser than I'd like; I still haven't quite mastered the #45! All done with hand tools apart from resawing the Alder plank in two; I started it yesterday afternoon and finished this morning (although it'll get more coats of oil over the next day or two).
The #45 I mentioned I hadn't mastered was the Stanley #45 Plough Plane (to cut the grooves for the base and the lid). The 45° mitres that form the ends of the mitred dovetails were cut with a chisel (and a bit of wood with a carefully planed 45° angle on the end as a reference).What do you use for the 45's a tenon saw or a pull saw & mitre block or a sliding chisel guillotine as like a picture framer uses
Can you not add a bit onto the lid to give you fingers something to pull on? might hide the mistake!A simple box made out of a lump of Alder I couldn't resist when I visited Wentwood timber.
I have done something metalwork related... First in months. Still no ideas of turning stuff for the lathe..
View attachment 366819View attachment 366820View attachment 366821
@Onoff It is mostly ready for plaster and casting I think.
Yeah holes are to degass the plaster, whole thing inside vac chamber.
