slim_boy_fat
- Scottish Highlands
^^ Many thanks! ![Thumbup :thumbup: :thumbup:](/forum/data/assets/smilies/thumbup5.gif)
How do you connect multiple lengths nick? Looks like you have the support bar extending past the convex?More of these familiar handrails and posts,the blank ends is the join as it’s 6.2m,stiffener bars of 12/16mm square on underside.View attachment 380722View attachment 380721
That’s a joiner,protruding 40mm,I’ll site weld it top and bottom.How do you connect multiple lengths nick? Looks like you have the support bar extending past the convex?
I use one of these from Eccentric Engineering on my Boxford STS lathe. I mount it in the toolpost and run the lathe in reverse (camlock chuck).@My Old Landy Do you find the rear toolpost a LOT better for parting off than the 'normal' one?
Something I've been considering getting for a while.
I didn't know elephants came in seedsWee box, containing a seed, containing elephants
Should be easy to make a simple one?I keep looking every so often for a M300 travelling steady in the vain hope that a reasonable price one has popped up on eBay etc, sadly not![]()
Take a look at trhe hand brake cables as well.Not so much made as cobbled together.
My little Peugeot 206 runabout had an advisory for unequal brake force on the rear wheels (only just within limits) at its last MOT.
Since then I've stripped the brakes down, replaced the shoes, hardware and cylinders and fully bled them, but didn't find anything wrong. As such, I've no idea if it's fixed or not.
Anyway the only way I could think of to test it and get an idea if they're the same both sides was to see what pressures I'm getting at the cylinders and compare one side to the other (Unless anyone's got any better ideas?)
So with a bit of fettling, I spent a couple of hours this morning making a couple of m8 to m10x1 adaptors to fit the bleed screw holes and cobbled this little lot together x2.
Pressure tested using an old cylinder squashed in the vice it held at 1500Psi / 100bar quite happily. So now all I need is for it to stop raining for long enough to get under the car and see what pressure I'm getting to both wheels.
Hopefully it'll be the same both sides and I can thus assume it should be ok on the brake tester, and if not at least I'll have a better idea of where to look next in the hope I can get it sorted before the next MOT.
View attachment 380834View attachment 380835
Does this run a compensator valve before the brakes for the extra weight of rear seated passengers? i had one on a micra gave me end of issues till i stripped and cleaned it
Is that what they are fitting in the new BMW?
I'm trying to ignore what badge is on it!Is that what they are fitting in the new BMW?![]()
