pedrobedro
Man at Matalan
- CX near Chesterfield
My good friend predictive text!
I suppose a turfor is a tow jack![]()
A Tirfor might be a tow jack, a turfor sounds like someone who lays grass
A toe jack is for lifting big heavy things from the deck albeit machines or whatever , hydraulic or mechanical. Most mechanical ones you bump into are in fact for railway track.nice work indeed,
but I did have a spare Honda engine.
Power to weight is pretty good, but it doesnt have a lot of traction...What's the 0-60 time for that saw?![]()
Crack right through this fork/shock. Replacements not available. The bikes themselves are apparently very rare over here.
Bevelled out with the Pferd ALU burrs.
Welded with 5356.
, I bought this motor on the 'Bay [1/4hp, 240V] new & unused for £24 to use on the bench linisher I'm planning, and for which I have most of the bits.
Short vid of a part of the machining, running low on battery so had to cut it short.
I don’t think it will have the guts tbh mate. Most hand grinders are 700-900W
My old 6" bench grinder is 350W iirc, can't remember offhand what the 8" one I replaced it with is rated at. At least the new one is shiny.....
I don't know how you could easily check the output, you could roughly measure the input with a clamp meter but that would not take into account the efficiency.Aye, I suspected as muchMy old 6" bench grinder is 350W iirc, can't remember offhand what the 8" one I replaced it with is rated at. At least the new one is shiny.....
How would I check the output of the other 2 motors I have, if at all possible?![]()
When the Cat is flying along at 15-20Knots into a force 8 you need something solidNice brackets Hood, look like they'd hold a CRT screen let alone a modern one![]()
