Vmax liners are 82.93 od, 76mm id
Quick question to the knowledgable, these liners are pressed in, how hot should I make the block? Planning to use my ceramic plate to warm it up, put liners in the freezers, and bang em in.
Buy the LED tube replacement and keep the light ?I made the garage a bit brighter, and also now have light over the workbench. Now have an old 6ft single strip light tovget rid of.
I've been having a problem with mice getting into a kitchen cupboard through an over size hole in the back of it for the stop tap. Unfortunately where I think the mice are getting in from outside is covered in decking so need a clear couple of days to lift it and sort properly. Made a quick plate to cover the hole as a temporary solution. Would usually make something like this from wood but had nothing thinner than 18mm so used a piece of scrap 2mm aluminium.
View attachment 208276 View attachment 208277
Har bloody harCeilings a bit low. Mind your head....
Some resemblance of order with some of my drill bits
Was doing the very same thing yesterday only to be disappointed at how many are blunt.
Won't they be inside the walls now, effectively having free run of the house?![]()
You should have kept it as a plate and drilled a single hole for the spindle unscrewed the bar holding screw . put the plate on with glue then put the bar & screw back in place as a mouse can get through a 1/4 " hole /gap .
Thing is the mouse is coming in through the wall … so the plate will still allow it to come into the kitchen .
Buy a couple of packs of Neo Sorexin CD rat & mouse killer and put a cut open one inside a jam jar wih a screw top lid 7 a 3/4 hole in the lid . lay it on it's side in the cupboard . if you notice th posion has been consumed replace it till you reach the stage of no more being eaten ..the problem is solved. For the time being .
If you don't like the idea of the Sorexin buy a steel bodied mouse trap ( they are the best around ) & bait it with bacon rind , pop it close to the stop tap , refill the cupboard check it daily . If you catch still set it & keep checking it … mice & rats follow an incontinence pheromone trail which hangs around for a few weeks .. a new mouse will smell & follow the strong trail as it knows it's safe return and on a food route .
I know its not metal but i managed too finish these display shelves made from MDF today they are about 6 feet high, The person said make them coral colours? oh well lets see how they like them. Lego man for scale.View attachment 208518
Today I’ve been sewing.
Got some off cuts of leather, my mums old sewing machine and made a low profile tig torch sheaf. Not perfect but I’m happy.
Anyone need their dress altering??
You are making a mortar?Mock up
Batman’s search light?You are making a mortar?
I have supplied an L bracket that gets fixed to the top and allowed a wall fixing, But it is a good point you raised as many people do not see the danger of furniture falling on people, I remember the Ikea drawer units that crushed a toddler it was shocking.Lovely job!I I hope they're going to be screwed to the wall?
Wow!, R2D2 has let himself go.Mock up
