brightspark
- yarm stockton on tees
max headroom
Looking at the size of your pads I was thinking it was a huge great shed. Which may have needed piling.hi
major over engineering has/is being carried out due to the size of free matters. its 3mx5m.
the concrete isnt just sitting on the dirt there is holes there.
Had the joys of a snapped glow plug...
Looks like I will be getting myself a glow plug removal kit if I can't borrow one from someone!
You don't need a removal kit for that, as the hardest bit is already out.
First thing I'd try, is fit the other plugs, wedge a rag over the broken plug, start the engine and let it warm up. Try giving it a rev as well, as it might be enough to blast it out. The rag is to contain the projectile, as it may come out like a bullet, so make sure nobody is stood anywhere near the potential path of the broken bit.
If that doesn't work, you just need to start drilling. Usually once you get so far down, the drill bit will grab the glow plug and it'll start spinning. At which point it'll either just pull out with the drill, or it'll blast out if you start the engine.
I'm sure I will get it outIf starting the engine doesn’t get it out try running a tap into the remains then screw in a HT set screw with a nut and suitable spacer , tightening the nut to put some tension on the remains should pull them out
just don't snag a drill bit and snap itI'm sure I will get it out
Just haven't attempted it yet
Let's hope not!just don't snag a drill bit and snap it![]()
