brewdexta
The biggest tool in the box
- UK
I had a couple of thin pieces of cherry that I wanted to rip in half so I made a tool to help me rip them accurately.
Here it is:
I guess you'd call it a kerfing saw or something like that. It's made out of oak, about 200 mm long and about 90 mm high; the spacers and clamp pieces are 60 mm high. I've made spacers in 4 mm, 5 mm, 6 mm and 8 mm thickness at the moment; I'll probably make some more in due course - they're very easy to make. The 8 mm one has more dramatically rounded edges than the others as I'll generally use that as the outer clamp piece when using thinner spacers and it makes it more comfortable in the hand having rounded edges.
The idea is that you fit a spacer about 1 mm thicker than the thickness of wood you want and then press the fence against the side of the wood while taking cuts all the way round the edge of the board. You then get a saw out and it's fairly easy to follow the pre-cut kerf.
Another view:
and another:
The flange-button head M5 screws you can see in this picture are held in place with 5-minute epoxy, so dismantling just involves the knurled brass knobs and no tools.
Finish is four coats of Shellac and one coat of paste wax. This was the first time I'd used Shellac. It isn't as nice to apply and doesn't look quite as good as the Tung Oil/White Spirit/Varnish mix I've used in the past, but I love the fact the coats dry so quickly so I don't have to spend several days applying finish.
It all started with this saw blade, which I spotted on ebay for £10 (someone had bought the wrong blade for their saw). I don't have the saw but I saw a potential use:
I snapped off the tang and drilled four holes in it - I was a bit worried about how easy it would be to drill, but it was quite straightforward.
Here's what it looks like inside the saw:
Here's what the result looks like with a 9 mm thick bit of cherry and the 4 mm spacer (this was done as a test before I applied the finish or made the knurled brass knobs - hence the nuts and washers):
The saw then follows the cut easily:
The result:
Planed to 3 mm and looking good to me:
I think this saw is going to get a lot of use, which is really satisfying, especially since I started and finished making it (including the knurled knobs and all four coats of Shellac) all in one day.
I like that a lot
