Memmeddu
- Italia Sardegna
I want one
I want one
Good luck with the job, is that the one you mentioned here a month or so ago?Now after dinner I've received a message from a local machinist asking for my curriculum.
He already knows I've never worked with machine tools ,so let's try
Yes it is thanksGood luck with the job, is that the one you mentioned here a month or so ago?
Mod number 2,welded a thrust plate between the inside of the channel,and the original plate bolting to the cross member.Quick mod this am,as I forgot to make a cut out for the top of the jaw to latch into.View attachment 276681
Received another messageSo
This morning on the jobsite ,laid electrical conduits.
Once back home , I've assembled back my Jonsered .
Last time I've used it.
Engine bolts threads stripped while cutting , and the engine detached from the chainsaw , damaging the new oil pump
So today I've extracted the broken bolts , drilled and tapped
Used new bolts with spring lock washers and locking nuts , and in name of safety semi permanent locktite.
Reassembled ,carb tuning .
He already knows I've never worked with machine tools ,so let's try![]()
She wants meet me![]()
Things are looking up for you Memmeddu![]()
This sounds like you have experienceEither that or she's a serial killer & sees an easy target to raise her tally.![]()
He escaped with his life but not his sanity!This sounds like you have experience
Cheers.Really nice work Robin
The former@eLuSiVeMiTe did you make the porch or paint the house? Or both![]()
