DAPPH
as dyslexik as I'm daft
That's nice & handy if the guys have the presence of mind & intelligence to use it .I came into my local men's shed the other day to see two of the guys drilling into the end of a 3" cylinder of wood about 9" in length with a fairly big Forstner bit. One was operating the pillar drill, the other holding on tightly to keep the cylinder level (kids, don't try this at home!). OK, so it worked, but the risks were pretty high to say the least. I decided to knock up a vice that could hold a piece of round, square or rectangular timber so that the ends could be drilled. Now we don't have any milling or turning equipment or other more sophisticated machinery for that matter, so everything I make tends to be done mainly by hand. The vice is a mix of offcuts and reclaimed steel including Dexion racking angle for the slide guides. It may look crude but it does do the job.
If you can't knock something up like that get the help of someone to hold it parallel to the ground in a vice and drill from one end using the Mk 1 eyeball to keep it on the lateral axis and your mate doing the other sighting line to keep telling you up a tad down a tad to follow the line of the wood .
For short pieces I often use a right angle of wood glued & screwed up out of 44 mm planed wood .. Turn it on the edge side , set it on a 15 mm square of ply to stop cutting right through and push the round or square wood into the crook of the right angle then drill down with the press .
