Nothing wrong with a 'suupply' just gives extra Uuuumph!Another laser cut box for the diesel heater ATX supply. Spot the deliberate mistake...
Added a few coats of spray acrylic and added the ATX breakout board and meter
Looks okay. The "high current" lead provided to the shunt is more of a resistor so will need to revisit that's it gets warm when the glow plug is on!
Meter is maxed out when glow plug and fan are going full speed. Might see if I can get a higher power meter in the same size as it useful to know what the heater is doing.
In what way was that a failure??? Looks great.The project was a fail
The challenge, Couldn't complete it. show working with what I had on hand to make.In what way was that a failure??? Looks great.
Ancient religious symbol from India and similar regions.Interesting design inside that lid.![]()
Rotate 45 degrees and it is different.Ancient religious symbol from India and similar regions.
Seen worse.
Er no, not quite but as I was an electrical design engineer, mine should be somewhat close to the regs.....
You are even better than you think, there are no numbers to paint by....
I'm getting quite good at this "painting by numbers" lark...
