others will be far wiser on hardfacing then me but if i was doing it farmer style id lay down some 7018 cross hatch pattern on it and then weld over that with a suitable hard facing rod.Another problem with this particular bucket is the plates on the bottom at the rear (machine) end which somehow get worn. I don't know how, the driver must crowd it back then drive with it on the ground!
Anyway, every so often I have to grind off the remains and weld a fresh one in place. I was wondering if it might pay to run over them with hardfacing rods? It would mean approaching my boss and getting the OK but I'm thinking it would probably work out cheaper than the current method?
one thing is for sure, its not going to fall apart anyways.There was some welding on the outside angle as well, though not a huge amount.
Using angle I think there is more support spread onto the bottom plate of the bucket which I think is a good thing on this, and I think it probably is stronger and may resist side loading better. Also, this bucket edge not only has force from digging into a pile then crowding back but also in the opposite direction as it gets used to scrape slurry. The driver will tilt it to near 90 degrees, push it down so the front of the JCB is in the air and drag it round the yard. You can tell the forces involved by the dust that appears as the concrete gets abraded away!
Also, I had the angle iron to hand (it's pretty thick btw) and a pretty limited choice of flat plate. Unfortunately I'm in a farm building that's referred to as the workshop because it has a vice and a pit, and the welder and two angle grinders live there. But that's about it! I have virtually nothing in the way of spare metal and tools, so a lot of things are a case of 'make do'.
must be painfully slow welding them on with sticks,
i just mig them on, the one thing a bit diffrent i do is stack some stays in from the tp of te bucket down to the bucket edge, for a bucket that going to do a lot of scrapeing push a slight curve on the blade so the middel of it scrapes better,
i would,nt put hardfaceing on any bucket thats been used scrapeing on concrete, bucket edges and wear blocks are cheeper and easyet to replace than concrete. the hardfaceing X's that some people like to weld on just trash conrete
A better way might be simply putting on special metal rubbing stripAnother problem with this particular bucket is the plates on the bottom at the rear (machine) end which somehow get worn. I don't know how, the driver must crowd it back then drive with it on the ground!
Most cow shed buckets have these on
Farmers are tight. Stupidly tight it will never change they never repair anything in good time and then it costs them far more
Heck I don't know why
Preventative maintainance seems to be an alien thing
Your workplace don't half seem an accident waiting to happen with all this tightness going on.
Bill, I get wear parts from john Moore in Staffordshire. The website gives some information on grades/Hardox etc, they are also very good on the phone for advice
http://www.wearpartsuk.co.uk
What is the special rubbing strip, hardened steel?
I am finding that ordinary mild steel wears away almost as fast as you can weld it - I'm looking at a muck grab now which has worn the wear plates away in no time, and it hadn't done much- plus half the time when mucking out the concrete floor is wet with the muck and it provides lubrication.
Inconel special wear resistant steel
You use preheat and use hydrogen consumables just to prevent cooling cracks
You can purchase inconel rubbing strip in the farmers gardien etc I think by lengths normally a rectangle. Bound to be routes selling normal bright mild steel ones though
