Richie before you start it ….lube the cylinder with the spark plug out ..give it several pull overs and squirt a bit of WD 40 in between pulls. Done so it lubes the piston rings & the cylinder wall and piston skirt . Other wise if it's too dry .....the rings might break or pick up metal from the walls & knacker the machine .
PS Your'e a jammy git finding such a score . They are brilliant machines if looked after .
Cheers Dapph,
I've got it running. There's a thread in the projects section with a little video. It always turned over very smoothly by hand before I had it under power. I got it running properly since the video with fuel in the tank.
Rich
