Moose McAlpine
- Norf Lund'n
Those are nice!
I used to deliver some for the film industry, hugely expensive when new.
...I have wanted to build up a monster splitter like the one below for a while now...
Yeah citric is the plan, to be fair most of it is just a thick layer of dust. Late model 3 litre, block markings indicate Sep 88That will come up well with citric acid, similar condition to the 383 Chrysler I did. 2.5 or 3ltr? I have a new set of ARP conrod bolts to fit an Essex.
bit coarse for bead blasting should have used some smaller ones1968 2.5 Essex piston from a Zephyr I rebuilt, someone dropped a ball bearing in from the carb!
Will have to Google it nowAmazingly Britannia Walk still survives. Off City Road.
@slim_boy_fat and @Welderpaul , the 15m pressure hose arrived that you were interested in. I bought it from here
Its far better than the stock hose, but at nearly half the cost of the whole pressure washer then it should
Its braided rubber rather than hard plastic which helps,
You can see it uncoils quite easily, the Karcher one is like a watch spring
This is the karcher hose, I guess if it was stretched out in a warm room for a while, or stick it in some warm water for a while then stretch it out then it would be a bit better but its always going to want to tangle up.
the two side by side, the new one is on the left, its a bit thicker but has a higher temp/pressure spec but is still more flexible and seems to have less memory. Its snowing up here so I won't be trying it out for a while. I checked it fits the pressure washer ok but that's about it for now.
Cheers
Andy
.A 14 rung extension ladder. Not sure why as I seem short on volunteers to send up it, but hope springs eternal, and it was free..
Ah! a volunteer....
You can do you aerial now
Ah! a volunteer...
First thought looking at the photo...… Is he going to baste it with that pot of oil on the mill ?
Noticed the wheels on your Tom Senior mill. Have you found any negative aspects to adding the wheels ?
