I have seen that weird offset before and that was described as a railway spanner to me. That one was a lot smaller. About 2” ish. I’m not sure if it’s just a description of the shape or if they are in fact rail / loco spanners.I bought a bloody big spanner, from FB marketplace. Sold as a "railway" spanner, I have knocked the paint / rust off and there is no railway markings and
no track ganger would have wanted to carry this far
There is a double ring affair as per the photo's ..I am guessing this is a manufacturers mark ??
I dug out my biggest bit of hex and it looks dwarfed at 2.5" accross the flats, The spanner has been used and started as a 3 1/2" inch but looks to been machined out by 1/4" on one side.
It will look good when bolted to the wall not sure what I am going to do regards paint may go chemical blacking
View attachment 302195View attachment 302196View attachment 302197
Them are very good, I’ve had a chance to play with oneA new saw.
I bet @8ob and @mtt.tr will be jealous of this beast, with it's whopping 4 inches
In all seriousness though, it seems quite capable for it's size.
Went through a 3" Scots pine, at a steady pace.
Filter the inlet - and I hope is been used with one - fine tolerances/clearance inside - ingesting much of anything will wreck it. One of our standard bits of kit used on our machines is a 7/5kW version . . .sucks wellToday I acquired one of the vac units for my flowbench via a cheeky bid off the bay of thieves
That that could double as a possible home defence solution to deal with armed intruders/attackers.
Finally turned up yesterday, these two have been on order over two months but well worth the wait, having the drill chuck on a Quick Change holder, bloody magic. Yes, this system and holders can run into money but well worth every penny, transformed the speed with which I can swap tooling:
View attachment 300393View attachment 300394View attachment 300395
Righto, off to earn a crust.
Are they white metal bearings?I picked up this ML7 on Saturday,
I now think its over priced, as its a little worn out
Spindle and bearings are worn, as is the bed and lead screw,
Having no experience with lathes
It has been a steep learning curve,
I have got it working better,
We'll have to see how it goes.
Any advise may be helpful,
ps: I do have all the covers etc.
Yes, they are white metal bearings,Are they white metal bearings?
If it is a first lathe just run with it for a while and try not to spend too much time or money improving it there is lots to be learned and even a small tired lathe is better than no lathe.Yes, they are white metal bearings,
I have adjusted them, scraping and shims etc, they are a lot better,
I think replacement parts may be the easier way to go,
Spindle and bearings, bed, lead screw,
edit:
I may be flogging a very dead horse
