slim_boy_fat
- Scottish Highlands
Which way do the pulleys turn
Spindle pulley turns toward the camera.
All I will say it is lucky Orkney is a long way away from LeicestershireI was being facetious![]()
Who says you cant live like a king on a peasants income!!
If they are any good I will go back for the other 30 packets tomorrow!
Doubt it. They’ve pallets of them at 10p in Tesco here.By which time they'll all be gone![]()
Picked up this old electric fire from a mate, cast iron and enamel and the same as the one i used to make toast on in the backroom when I was a kid, made locally by Revo.
Tip of the day: For toast lovers, Morrisons cob roll bread is great; Mmmmmmmm !Picked up this old electric fire from a mate, cast iron and enamel and the same as the one i used to make toast on in the backroom when I was a kid, made locally by Revo.
View attachment 328820View attachment 328821
We need aPicked up this old electric fire from a mate, cast iron and enamel and the same as the one i used to make toast on in the backroom when I was a kid, made locally by Revo.
On the heater?Tip of the day: For toast lovers, Morrisons cob roll bread is great; Mmmmmmmm !![]()
Perhaps a Moderator can change your avatar name to " I Want ! "We need a
I want button.
Much I need. Many item I would want. Many I like.Perhaps a Moderator can change your avatar name to " I Want ! "![]()
Yeah, I also find that some of the old things I remember while growing up bring back good memories.Much I need. Many item I would want. Many I like.
Some I do not like, or want or need.
Just something brings back a good memory
As soon as i spotted it i knew it would make a nice looking item for my pre 50's room which is going to get filled with nostalgic itemsWe need a
I want button.
My gran had something similar. That and an electric blanket was plugged into a 15amp wall socket.
Then like an old auto eject kettle lead they would be fired out.
I've never seen a mill but Arboga drills pop up from time to time, usually command a bit of a premium but they look very well built.Are Arboga machines (Sweden) widespread or even known among you?
It is really more a Mill/Drill, only for relatively light milling.
I acquired a look at and test run with an Arboga U2508 milling machine today.
All eight speeds run perfectly (100-2,900rpm - what a range without having to touch a belt).
When measuring the runout at the end of the quill, I first thought I wasn't measuring at all until I swapped the 0.01 for a 0.001 clock, then the pointer shook a little.
Now I'm having a hard time thinking ....
Have a nice evening
Carsten
