lazybones51
- Northamptonshire, UK
The things people throw out! It looks hardly used.
Skip dive. Needs a blade and some adjustment.
Blade choice is now a problem, too many options!Have one just the same.
An hour's work squaring it up and fitting a zero clearance inset for both the blade and the fence and it cuts comparable to something much more expensive.
I only cut wood on my mine so I replaced the generic "cuts anything known to man" blade with an Evolution-compatible TCT blade from Saxton Blades, and the difference in finish is very pronounced.Blade choice is now a problem, too many options!
Yea i get offered them all the time from customers houses and knowing what i know i always decline...so light there's less scrap value than man hours too. Having said that if i had the room for one i would love a greenhouseStripping and building one of those is a lot more work than it seems. I had to demolish one once and thought about re-locating it for a few quid instead. soon changed my mind![]()
Thanks, I had a look at Saxton Blades and ordered a pair, 40 & 80 tooth TCC for £26.99 delivered.I only cut wood on my mine so I replaced the generic "cuts anything known to man" blade with an Evolution-compatible TCT blade from Saxton Blades, and the difference in finish is very pronounced.
The original blade works fine but for a better finish the dedicated blade is world's apart.
Not sure if I ever need so much power.
But they are cheap as dirt.
300 for both.![]()
