Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Alll that it is collets.What's the part that interests you?
Carsten
What's collett in German ?
Carsten
= "Spannzange" singular, "Spannzangen" plural.What's collett in German ?
Without water there is little to no problem.
With water, ie absorbed from the air over time, it becomes a problem - hence all the recommendations if you don't use a car much (with aluminium tanks, carb bodies etc) the advice it is to use low ethanol fuel, use a stabiliser, or drain it.
Not an issue if you are regularly using the fuel - it won't have time to absorb much water.
In reality, you probably won't notice much - but it might just be worth an inspection every now and again.
I stopped using a couple of jerry cans from the late 80's as the internal paint was coming off (and one has a slow leak on the seam). But two 1940's war dept jerry cans that I inherited from my dad still seem to be resisting modern fuels well - internal paint still attached. What did bemuse me was the scrap of 1960's newspaper I fished out of one a year or two ago after several decades of using it myself . . .
Exactly - used.The fuel tank on my bike is aluminium and it looks like new inside after 14 years and 110,000 miles of round the year riding. Even the ones I have had that were thoroughly encrusted in oxidisation on the outside were still like new internally.
I'm impressed . . . joining those two . . .Then again that might be because I mainly weld aluminium and stainless![]()
I welded some aluminium to stainless a few days ago. Well when I say I welded it did look goodI'm impressed . . . joining those two . . .![]()
I've got hundreds of those inserts - all sandvik
A little something for milling and turning.
An end mill for indexable inserts, the triangular ones that are still quite affordable even in quality.
Thanks for the tip, J.
25mm shank, Ø 50mm, indexable inserts TPKN16.
A couple of inserts like I need for turning and two left hand insert holders in 10mm which I was strangely missing and need until I could increase my center height.
Nice evening all
Carsten
YepWhich ones, the TPKN16?
