Other Daniel
- France, Charente
Baler Knotters are Dark Magic...
It's off a water hardness testing thing, it dosed some chemical into a volume of water and looked for a colour change I think.could be off a commercial dish washer poss the atuomatic detergent feed
And fewer people around that have any experience of them.
I dont mind the knotters, its all mechanical so you can see any wear or broken bits rather than this lift arm which seems to rely on pot luck! any breakdown is worse when its in the field which it always is!And fewer people around that have any experience of them.
Says the person who is probably for half the posts on this thread in the past few weeks
Ah, so nothing new from me for too long?!?
Our JD baler has a knurled steel centre in between those washers. It works well enough, there is loads of tension on the trip arm so it's pretty accurate. I'd say once you replace that piece it should be right as rain...So its this, the part I showed the picture of is sandwiched between those 2 big washers on the left of the shaft, as the hay is stuffed into the chamber it turns that big angry spiky wheel that turns the shaft and the roller im replacing, the arm above it is tight against the roller so as it turns it lifts the arm up, when it reaches a set point your bale is done, the problem is the friction between the roller and arm or lack of friction so hope fully this should sort us! every year I keep looking at it thinking of betters ways to do it but you need a field of hay to test the ideas!
I have a D2 at work and a D1 in my own workshop, they are both great but I'm perfectly happy with the D1, it's done a lot of work for me.A Leica D1 swiss tech made in china guess what it doesn't come with a case and needs an app for full function
Maybe destined for the glove box ,thought it was cheap !
Flatpacked
Dobbsic,
Watch out for shortness of breath , loads of fine white frothy milky sputum , chest hurting , feeling faint & a lump in either groin , seems you have a fair chance of getting blood clot after such an operation . Mine was close to being fatal , it appeared almost three weeks after the event . Nobody told me of the common blood clot risks or what the symptoms were .
I see it was nicely palleted for you!I acquired a picnic bench, some assembly required.![]()
Baler twine - posh blue stuff - from my grandad - supplied us with washing lines, gate hinges, parcel strapping, go-cart steering, shoe laces, belts for years as kids . . . slumming it with some old common red stuff at the momentBaler Knotters are Dark Magic...
I 'd have been concerned about the removal of unmarked ( now in a higher voice ) swellings too@dobbslc , it's frightening the number of wrong legs (for example) that have been amputated by simple error.
Everyone gets tired and makes mistakes.
All the ones I ever worked on had a knurled steel centre too. It's been a long time, isn't the arm spring loaded?Our JD baler has a knurled steel centre in between those washers. It works well enough, there is loads of tension on the trip arm so it's pretty accurate. I'd say once you replace that piece it should be right as rain...
I had that in reverse when I was going for employment as a food factory machinery commissioning engineer . His nibs said, "Draw me a three phase contactor switch " so I drew the schematic , he wanted me to sketch what one looked like .. " .When I was a lad my dad went for a fitter's job and the interview was "explain to me how a baler knotter works". My dad said he couldn't explain it in words but he could draw it if he could have a pencil and paper. Guy said "sorry mate you're not good enough".
