Sure. I've seen similar with a Dremel. I'll practice on something easier until I get the hang of it.You be careful with that. Working inside a tube/hole/port you can sometimes get the cutter running around inside it. Can make a mess of things quite easily, and sometimes even bend the shank. Air grinder is a lot easier and safer in this respect, but make sure to hold it in the spot you want it - don't let it waggle around.
I got a new 0.55kw single phase motor to replace the 3 phase one from my Viceroy polisher but it’s massive and probably won’t fit.
Is there a Morden motor that doesn’t have a massive fan on the back? The new one’s an IM B3 and it’s a good 80mm longer than the old one of the same power.
I can only imagine how many thousands of the cheapies are sitting forgotten in live circuits in attics and behind panelling, quietly rotting away, ready to let the smoke out sometime.Just got some 8-way WAGO copies, FAKOs if you like!Fresh from the Guangzhou Dangerous Toy & Lawnmower Company.
Not using them on mains, just for my gate photocells.
First impression is they're made from more brittle and lighter weight plastic than the real thing. Shown next to a genuine 5-way. Not sure they'd pass the drop test.
I get that from time to time, and have a few bent burrs to prove it. Obviously I haven't thrown them out, just in case.You be careful with that. Working inside a tube/hole/port you can sometimes get the cutter running around inside it. Can make a mess of things quite easily, and sometimes even bend the shank. Air grinder is a lot easier and safer in this respect, but make sure to hold it in the spot you want it - don't let it waggle around.
I have straightened all my bent ones - usually by eye, sometimes by tapping the cutter still in the grinder against something, if not too badly bent.I get that from time to time, and have a few bent burrs to prove it. Obviously I haven't thrown them out, just in case.
I pulled a couple of De Walt plastic cases out of a skip the other week, both had catches missing, and both missing catches were inside one of the cases and just slipped back in place. I've still to find something to put in them.
Them lot in Suffolk are weird!
That never seems to be a problem for long, that Bisley drawer in the picture above is the one I got last month with no use in mind, it's already full.I've still to find something to put in them.
It was an Essex skip actually, them lot are even weirder.Them lot in Suffolk are weird!
Send it to me with bottle of your brew in it, I will then make use of the case after testing the beer. Sorted. Shall I PM you my addressThat never seems to be a problem for long, that Bisley drawer in the picture above is the one I got last month with no use in mind, it's already full.
It was an Essex skip actually, them lot are even weirder.![]()
Somebody who doesn't have a clue what they cost.
Unfortunately I paid cashPaid on a card or App?
