redlig
- wiltshire uk
Thanks for reply. It looks as if I can utilise my vertical mill set at 90 degrees . Small mikron thing.Sure. I bought mine from here:
End Mill Grinding Fixture Base
www.amadeal.co.uk
You'll need a surface grinder and mag chuck.
It's very easy to use as it has all the necessary angles built in. I bought the 5C version but there is an ER version if that is what you need. I have a box of b******ed end mills given to me for free from work and I can regrind one from completely kna****ed to dead sharp in probably less than 5 minutes. They look as good as new. Ends only of course, not the flutes. I've tried it with 2 flute slot drills, 3 and 4 flute end mills. It would work just as well with others. The only thing I can't do at present is cut a new gash (I think that's the term) as I need a miniature grinding disk, and I would like something (suggestions, please...?) to grind a new centre / hole in end mills that I need to regrind the ends off completely.
