Ours was a Universal end remove plug hold in and crank was for Petrol though Cracking tool, Card out staple it to job card.Ebay, seems no problem, it is just that you need a car specific adapter an a short piece of hose with a specific quick connector both ends making it costly for a tool I might never use
Diesel needs an adapter in the glowplug so think i will make one from an old one then and there.Ours was a Universal end remove plug hold in and crank was for Petrol though Cracking tool, Card out staple it to job card.
If the Card holder is not tethered suggest you make one they go walk about
Errrr, that's a film strip you have in it. (sorry, couldn't resist )Most exciting is the slide duplicator
It has a slot for mounted slides, and back in the day when you'd be copying from film to film, you'd use slide film (colour positives), so I'm sticking with slide duplicator.Errrr, that's a film strip you have in it. (sorry, couldn't resist )
Pleased to see your progress.
I am wondering now what happens if you duplicate a negative onto negative film, you'd get a positive image with a strong blue cast from the orange base I think.
Thanks for your information, I really appreciate it, and it helps me understand what I need.The one we had was a stylus on a sort of calibrated waxy paper, you clicked the trigger and it moved the graph holder up one cylender
Looks like it is all there, little arm moves across and. takes the white surface of the card leaving a blue arc, the surface was calibrated in columns.
Remember to release pressure before clicking to next cylinder or it scribes an arc going back.
Making cards No they are quite hi tech really there is a calibrated preasure grid and cylinder No on them, surface is white and stylus takes that off leaving a blue trace
Oh, I've got something like that, I don't think I've got the correct adapters to use it in my engines. I picked it up from an autojumble because it was only a fiver, interesting to read that the cards are still available. I'll have to dig it out, see what's different. It has some adapters with it, I think.View attachment 405769
Was given this as new tester, does need some accesories still.
