The delivery was delayed by carp weather and carp couriers, but the Creality Ferret Pro 3D scanner eventually turned up.
Comes in a nice case.
Looks to be in one piece but no time to play at the moment, work keeps getting in the way!
The top bit is the scanner, the brick in the middle is the wireless bridge and the rest is the tripod.
EDIT - the tripod handle at the bottom is also the battery, so shoved it on charge so I can play later.
Did you get distracted halfway through taking that photoAnother useless waist of hard earned cash I was pushed into by this forum.View attachment 480862
Need some more storage on the wagon for those "not used very often" things that can live under the sleeper cab, so OH acquired these from the bread tray mountain at the food bank where she volunteers:
Picked up a couple of 50 tray storage boxes for the workshop so I can carry on tidying up all the nuts and bolts and such like. No more fiddling with my small parts![]()
Which should tidy up the awkward corner and let me get rid of those flat parts box things which I've never got on with. Invariably what I need is in the box on the bottom...
And hopefully end up with 3 like this, all sorted and labelled:
71 trays of assorted nuts, bolts, washers, crimp connectors, fuses, heat shrink, jubilee clips, springs, roll pins, pop rivets, and other stuff later, just need to label the trays and put them in some sort of order:
Is the idea of the track guide to simply replace using a cheap 15 mm x 100 mm baton the length of the work piece clamped down on it as a guide ?View attachment 480881
Evo 185mm circular saw and tracks.
Finally killed off my cheap black and decker circular saw so thought I'd upgrade. Couldn't justify the price of some of the proper plunge saws.
I like the idea it can cut different materials with the blades on offer. Seemed to leave a very nice finish on some test cuts this afternoon.
I bet you'll curse if what you want is in the bottom middle purple box .Carpet tiles are down and another set of really useful box drawers turned up today, I am feeling very organised
Yes absolutely, also has a splinter guard for less tearout when cutting. 2 x1.4m for cutting down full sheets. Will also suit other plunge saw brands if I ever upgrade in the future.Is the idea of the track guide to simply replace using a cheap 15 mm x 100 mm baton the length of the work piece clamped down on it as a guide ?
These are the drawer system they make, but I know what you mean I had boxes 6 feet high in my shed and always found what I was after was in the bottom boxI bet you'll curse if what you want is in the bottom middle purple box .
Next project .... carefully design a self supporting shelf set of folded plastisol sheeting securely bolted at the back & front ends to 30 mm hollow box section with a decent space between the shelves ??
