Blobber
- lincolnshire
Only the urge not to spend money until I get the light bulb moment!Though it might be a weird quirk or some such you have.![]()
I do that with parcels that are too big to fit on the scales....I have to ask; Why do you need to hold the parcel whilst you're weighing it?
Very niceHad my eye on one of these (or similar) for a while...
PALSTAR AT1500DT 1500 Watt Differential Antenna Tuner
PALSTAR AT1500DT 1500 Watt Differential Antenna Tuner Palstar Quality, Innovative Design The AT1500DT 1500 Watt differential antenna tuner is the next level up in power handling from our popular AT1KP 1200 watt differential antenna tuner. It is built with the same quality and care found on...www.radioworld.co.uk
I'm not likely to need or want a bigger amp than the one I've got, so a nominally-rated 1500W tuner will do nicely and should be well under-stressed.
Manhood, it's good stuff went through a few branding changes before going.stamped palm tree
Yep, except our bathroom scales retain the weighed value on the display for a few seconds after the parcel/body is removed.I don't now! You ever tried to weigh a big parcel on bathroom style scales you can't see the display!![]()
Well, the 15mm won't see much action.
Aldi seem to be dropping the line
Really?
Today I acquired a couple of batteries and a charger for my Ferrex gear, Aldi seem to be dropping the line so I thought it best to grab some spares.
Bob
View attachment 415019.
