JOEPRO
- UK
If there isn't already some kind of review on here I will unbox it tomorrow and do one.
Bob
Gaz tube to the rescue
Bob
Not the same model, not the pilot arc torch with I think.Gaz tube to the rescue
Reckon so, mines an A1 but got a Parkside pilot arc torch for it from Germany.The current one is a revised and presumably cheaper to manufacture model with a suffix B2.
Is Arnie short of work or cash ?Not the same model, not the pilot arc torch with I think.
Certainly not conclusive cos it depends on a load of things, but did a back to back on some 5mm flat steel and the non PA had more beans than the PA torch on the same machine...
I though I was dreaming today when I saw an Arnie Lidl advert on ITV - but no! Must be hard up...
Come on @8ob Give us a review, show us your muscles and best terminator impressions![]()
The nurse at the care home my mum is in did . . .Nobodies mentioned scabies, much fun.
Bunged up @8ob ?Today I acquired my favourite snack from Lidl's.
And on the way out I had an @MattF moment
Ah no. Of course you're correct. Sorry. I wrote it wrongNo. "It's" is a contraction. "Its" is the possessive.
Should have said I was taught that if the I-T-S expands to "it is" or "it has", then it's "it's", otherwise it's "its".
Tch.isn't a bad apple its just his
Barely a day after joining the forum and the dark forces compelled me to bring this home. It looks like it was made to fit the space![]()
Don't they do a drain cleaner for the pressure washer?Bunged up @8ob ?
Maybe you can use the plasma cutter if the prunes don't work...
Got to keep your brain active if nothing else, looks like a good little kit stick some pictures up of the build!
Err no......I have 2Have you got a lathe yet though? (That compulsion will start shortly too)
