- Birmingham
For screwing in cup hooks.Not sure what this bit is for though
That last bit is a hook driver, for curtain hooks and the like. Not particularly easy to use, but can save your fingers.
Yep that makes sense now!& works with wing nuts.
For wingnuts.Along with the Christmas tat in Aldi I managed to find a these, nice selection of security bits, probably made of cheese but a good get you out of trouble selection in a decent case
Who did you use for the hinges pls? My preferred suppliers feel pricey & don't have many optionsI decided to bite the hinge and get some bigger bullets...
Insulating fire bricks for scale
The smaller bullet hinges will probably still be useful: rather than being sensible and buying a "project box" for the control cabinet for the heat treatment oven, I'm currently planning on making something from scratch. The big hinges will be good for the (relatively heavy) chamber door, but the control cabinet door is likely to be a lot lighter and so I can use the little ones.
I bought one of their cheap 1/4 drive socket sets probably 10 years ago, expecting it to last as long as a ten quid socket set could be expected to . . . Still going strong, including the 10mm I slimmed down in the lathe to fit a tight spot. So you might be surprised.Along with the Christmas tat in Aldi I managed to find a these, nice selection of security bits, probably made of cheese but a good get you out of trouble selection in a decent case
Amazon (mostly out of laziness)Who did you use for the hinges pls? My preferred suppliers feel pricey & don't have many options
Once I factor in the first of purchasing the machines then my suppliers seen cheap
Had one for years but never knew what it was for, not that I tend to use curtain hooks a lot.That last bit is a hook driver, for curtain hooks and the like. Not particularly easy to use, but can save your fingers.
If only! That'd mean I'd have to start being nice to people & I like to keep my options open...Purchase? BORROW!
Can I come round for a lube job?Today I acquired a reel system, engine oil,air grease and hypoid. Complete with all of the barrel pumps and grease pump.
Bob
View attachment 476038View attachment 476039
Only if you bend overCan I come round for a lube job?
