DAPPH
as dyslexik as I'm daft
I've had one of those this last two years.. a brilliant bit of kit of the home user who doesn't do much above 6 mm in steel or 4 mm in non ferrous stuff .
I'd about to try using it today to braze a stainless steel 10 mm mesh sidewall to around perforated galv steel sheet 300 mm disc to make a strainer for a shallow manhole type hole .
May I suggest you keep it covered with a large bit of old light poly cotton sheet tucke under it when it's not being used to prevent it attracting particles of dust & metal to the circuit boards when you do any grinding . I hope to make a full dismantlable filtered enclosure with a front & rear opening flaps /doors to allow me to switch it on , setup & adjust it for MIG or TIG welding .
