MikeBB1970
- Hayling Island UK
YOU did not share.
I did - I told you about it, ergo I shared [the information]
I think I need to QA it(ALL!)
Both these started me thinking.
When I first bought my convoy I serviced it myself. the Jersey equivalent of eurocarparts gave me the filter for a tdci rather than a tddi by mistake. Finer filter and had identical issues.
Swapped it out this morning and it's been good as gold. Pulling better too.
Good news. Saves me running the car full of tools for a few days. Mot and service Wednesday
Not going to happen.
How mean.
I thought he was being nice & polite. I'd have just gone with "f off".
Me too.Glad it is sorted, I cut my old filter open after I had swapped it to check inside and it was black and gunky inside, it had only been on 11 months, think I might need a tank clean.
Good luck with the book, I've heard it can be very absorbing.......
That is because @slim_boy_fat has manners.
Is that the brushless model?Pressie to me, justification is that I need to get some 25mm box from the steel suppliers for the kitchen cabinet base build and will have to cut them down to get them on the trailer won't I
Spoke too soon.Both these started me thinking.
While in town om Thursday, I popped into MacGregors Ind Supplies [ideally I should never be allowed in there unsupervised ] to get some more gloves and left with them, plus this, a 10" x 3" blank of spalted beech thinking I could use it, cut to make 2 off blanks 1.5" deep each instead of using the oak I mentioned in another post. I'd then have the oak + a spare beech blank for something else down the line. I bought it because I liked the pattern(s) in it - the outside of the block feels to be covered in wax, perhaps some of our woodbotherers [@The_Yellow_Ardvark?] can let us know why that is? It is obviously removed in cutting/turning.
However....I Googled 'spalted beech' and discovered that the patterns in the wood are caused by a fungus, harmless to most folk but potentially dangerous for folk like me with a compromised immune system from the myeloma.
So, unless the chap up the road can accommodate it in his band saw at 10", then turn it in his wood lathe to give the 'barrel edges' I'm after for the small project, it'll be going back to MacGregors for a refund, or at worst a credit note.
You learn something new every day.
Check the fuel pressure, I’ve had problems with several common rail engines with exactly the same symptoms. Changing the fuel pressure regulator on the end of the fuel rail has cured them . Some diagnostic equipment can give a live pressure readingSpoke too soon.
Playing silly beggars again today. Roll on Wednesday.
