I hate anything with a soft start...if you add up all the times you have waited for soft starts to kick in then we have probably wasted about 2 whole days of our lives looking at a disc or blade
Little 400mm wide set of slip rolls. Rollers are about 35mm dia.
Rolled up some 1mm aluminium for a test.
Its come out at 43mm i/d (Didn't cut to size)
Where did you purchase this from and how much?
I’ve the afternoon changing the front ball joints on the Shogun. Most stressful part of the job was trying to get grease into them with my Sealey grease gun. Grease everywhere expect in the ball joint. Got there in the end but too much time wasted and cleaning up afterwards.
That is a lot of beer tokens. SKF do one too at half the price, I may have to take a gamble on that instead
They look a bit of quality, nice size too.
Visited Carew market and boot sale near Pembroke Dock this morning and spent more than I wanted!
One guy selling refurbished tools I got a rake £4, bolster chisel £2, lump hammer £4, sledge £5, then I found a mullered lump hammer in another stall for £1 and an axe handle so I can repair the hammer for 50p!
I was after a strimmer for tidying around the van and found this multi cutter for £50 so I couldn’t leave it there.....
Then a handle for my damaged spade for £4View attachment 184791
Then I came across this young pikey in a transit selling power tools TOOOO cheap and scored this Bosch SDS for £15. I was unable to check it anywhere so have been on pins all day until I got home to check I didn’t waste money. My heart died when it didn’t start but I found the N had pulled out of the 110v plug
Walking the dog this morning I took an extended walk and ended up near(well in) some old small buildings. They have been striped years ago. Oddly there is not much vandalism.
But I found this.
This is after a tickle with a wire brush.
Vono Bed spanner. The design allows it to be used on 4 different size nuts.
Today I bit the bullet and hopefully bought the Rolls Royce.
I'm fed up buying bits of useless junk that airlock, can't be bled, spew their contents out, don't screw together properly, quit pumping half way through, the plunger jams and are generally cheap awful tat.
So l purchased this
An Abnox Wanner grease gun
Hopefully this one will last and work properly
There's a technique to getting them off , top pumping tip the delivery tube /hose slightly side ways then pull , straight pulls are not meant to happen as that's when the high pressure grease is supposed to be transferred .Interesting. Every one i've ever used has been rubbish. They work fine when they're new and have a full cartridge, buy it all goes downhill fast. My cheap nasty work one is rubbish, the end nozzle always gets stuck on too.
That’s all that’s wrong with this country all summed up in one line.Nice bit of Racial stereotyping to start.
By your own admission he is selling stuff way too cheap,yet you turn a blind eye and buy it anyway. Then you gloat about it on a public forum.....
Sincerely hope somebody benefits in the same manner when said “Pikey” empties out your workshop . But hang on, that’s alright because they “needed it”, therefore you won’t be upset when they buy your stolen stuff.....
