Sammy7
- Sheffield UK
A surface grinder, been under a tarpaulin for 10 years. The bellows are intact so under the grime there's quite a nice machine. Ignore the half-stripped state, the only thing I can find is missing is the reflector for the lo-volt lamp.
Needless to say you won't recognise it as the same machine by the time I've done with it.
That would be me, technically I didn’t *need* it, as I’ve the J&S sat under a tarp, but the price was rightYou're the 'one other guy' who called on it? I was shocked when he said he only had 2 calls. Apparently I happened to check the site right after he listed it.
“Unicol “ now there’s a word I haven’t heard in many a year! Audio visual installations?
View attachment 202231 A new (to me) precision, adjustable spanner via @lchris21 from used equipment forum. It’s brand new, struggled a bit on rusty m16 bolt but a cheater bar would have made it easy. Added benefit was the accurate read out of the exact distance across the flats
Mines a decent machine, one owner from new hardly any wear. Picked up an eclipse 18"x6" magnetic chuck yesterday only went to pickup a compressorWe surely can, I have a whole load of projects to bring along this month and this'll be one of them. Just FYI it's a Mk3 Eagle grinder with coolant trough and 8" wheelhead.
Yep, and if you know an alternative use for Unicol poles I would be interested. Don't say exhausts, I know someone who made a straight through for his Hyundai Coupe from them, not good.![]()
View attachment 202232 Definitely an improvement on my previous precision adjustable which was limited to 25mm / 1” AF
I fashioned a cone to guide the gases into the silencer (actually, it was a cone from the Hardle guts that I'd thrown out), migged it into place and stuffed a couple of stainless steel pot scourers in the space.
Sounds much better, but need to see if the annoying blat is gone on the road.
Took a punt on a cheap and cheerful Chinese wind deflector, as the screen is just a couple of inches too short.
It's not bad for quality, far exceeding what I expected for the price. Time will tell how well it holds up to being banged about by the wind, though.
https://www.aliexpress.com/item/32954100011.html?spm=a2g0s.9042311.0.0.55174c4doz5B3B
