Agroshield
...would I lose the versatility of the machine once converted?
If you include three MPGs (manual pulse generators) in your CNC setup, you can drive the machine in the same way as a manual machine. They are a lot cheaper now (about £20 from a GoodBang near you) than they used to be. In the old days, when they were pricey, normally only one was used, but then you had to remember to set it to command the correct axis - cue much profanity and broken tools when you thought you were moving X- and you actually moved Z.
