I'm pretty sure every shaft will have a tapped hole in the end.you can just about see all those caps that i assume you can draw the shafts through , no idea how though
lLovely job!!
How did you strip the paint and clean the drill up? I have a progress drill to do so all tips greatly appreciated!!
i havnt changed many bearings in old machines like that but i wouldnt of thought that finding metric bearings would be common.
happy days tho but as ronan says, id check before just in case.
i have a pair of spindle bearings here that dont look too special out in the open but id set you back £500 odd.
your making a mighty fine job of it so far, it ill look amazing when its done.
you might of said before but what brand and kind of paint are you using on it?
slightly worried by the massive bearings that are underneth it !
