hotponyshoes
- Somerset. Uk
the less volume you have at at top dead center or whatever kind of piston you have, the more efficient it will be?
anyone left over it just wasted space?
More than likely right. I think the depressions in the pistons are more for mixture distribution and burning than the compression.
But say the depression is 100ml and the piston swept area is 1litre, it will pull in 1litre of air on the inlet stroke and compress it then 1 litre of compressed air will go out.
The 100ml area is not going to drop below whatever backpressure you have at the outlet and might actually be usefull for starting the piston off on its downward stroke again although it will work against the new air being drawn in.
There will be 100ml of dead space which (using the numbers above) might give a 10% drop in compression ratio? Or not?
Yes, I am overcomplicating it. i thought that was the point of the question. Clearly a converted engine is not going to be as efficient as a compressor engine. Some of the more difficult problems beyond just getting it to work at all are issues regarding lubrication, overheating and compression ratio.
Most cylinder heads will have a squish band which can't be good for compressed air generation, it will unnecessarily heat it up for a start. If you stick oil in the intake it might even start running! If you don't stick oil in the intake, how is the cylinder going to be lubricated? Its why they (used to) put lead in the petrol.
Efficiency is the big issue for me though. unless there is a particular advantage over using a regular compressor beyond "oh I just happen to have a spare V8/VW engine I am happy to sacrifice", I don't see the attraction. You can turn a compressor motor over easily by hand, an internal combustion engine is a different matter. It is not optimised to run at the speeds you will use for air compression, my gut feeling is any engine would be too "tight" and half the energy will be lost in just driving the crankshaft.
Emergency use only would be my conclusion.
Lubrication and overheating should be easy to deal with. Use the existing oil pump and cooling system.
Compressing air heats it but it cant generate any more heat than the original cooling system can cope with considering that was pumping the same amount of air plus hot burning fuel.
If anything it probably wont run hot enough for the oil to work correctly so might need that changing.
The hard part of turning a normal engine over by hand is the valve gear springs. A v8 block with no heads on can be turned by just a hand on the nose of the crank.
