The average engine compression is 130psi
At cranking speed. I would expect it to be more at running speed.
In terms of compressing air it will be the same at any speed. The amount will be dependent on the compression ratio.
The amount will be dependent on the displacement of the cylinder, nowt to do with the compression ratio. The air's not getting compressed in the cylinder, whats left in the gap between the top of the piston and the cylinder head will still be there when the piston starts to go down.
There will have to be compression in the cylinder to overcome the exhaust reed valve as pressure builds up behind it when closed
id use a rover v8. have the centre 2 on each back firing and the outside 4 as compressors, take the pushrods out to take them out of the normal valve sequence, leave the exhaust valves in to block the port and remove the inlet, fit poppets to the inlet valves and the spark plug holes. . should work quite well and i cant think of a simpler solution. will obviously need to fit a modified intake manifold too.
A lot of guff has been written on this by people who should know better - stuff about compression ratios, 10 bar pressure, not a lot or nothing in fact about controlling the engine.
It's simple, at least I think it is. You modify two cylinders to be fully scavenging - ie no space above the piston, so they empty fully. You have the normal pressure switch and unloader for control - effectively stop start, or rather start unloaded, load up, once up to pressure unload, time delay, shut down, repeat.
Lastly I would bin the carb and run it on lpg, with some means of cold start enrichment and a blowback valve...
I still think an old crossflow would be ideal due to the flat head....
I think you mean the opposite of what you're actually saying. Scavenging works by introducing an overlap where both the intake and exhaust are open at the same time. It's a gas flow thing and frankly, best left to those who study fluid dynamics because the calculations are horrendous. Certainly the stock valve timing is going to be a big issue with compressor engine hacks but my simple evaluation suggests the last thing you should expect is efficiency.
Having "near zero" space above the piston is like saying maximum compression and implies some serious modifications to both the valve timing and the valves themselves. That could also lead to unforeseen side effects and I rather suspect you'd be generating a LOT of hot air. What benefit do you expect to get from "no space" above the piston?
Some of the older indirect injection diesels could be reduced to very little cylinder space with a thinner head gasket. Should be easy enough to blank out the injection chamber or even fit it with a reed valve.
Save messing about with the valve timing just remove the camshaft, weld the valves shut. Use the ready-threaded injector and glow plug holes for nrv's and job done.
I still think there are easier/better ways of making an engine driven compressor if yoynwant one fitted in a running vehicle.
An aircon pump looks ideal to me. Maybe fit 2 of them (might find a 2nd bracket from a lhd car?) Set one on a high ratio pulley for quick tank fill and the other on a low ratio to build up higher pressure. Switch the existing 12v clutches with a tank pressure switch.
Turbos also blow out a lot of air. Fit a exhaust manifold and turbo to a non-turbo engine and you could use the output to fill the tank quickly. Not sure how much pressure a turbo can generate but I think F1 ran 5bar at one stage. The boost is limited to protect the engine which would not be an issue so I expect you could go a lot higher. Possibly need sequential or compound turbo charging.
I can see it being an interesting project but in real life I'm sure just getting a compressor head and belt driving it from a air cooled engine would be a lot simpler, cheaper and probably more efficient.
Edit: Tractor pulling contests in the states seem to be claiming up to 300psi of boost from a turbo..
