The one joint i can never get the same results on,in other words i'm rubbish![]()
I haven't done any for ages and it's like learning to weld all over again every time.No but if your welder runs them it will go v down as an alternative (don't do this with a, 6013).I have an inverter welder . The weld pool keeps running down the joint no matter what I do its mostly the joint . Would 6010 be better
That's because of gravity helping you o. V down but you won't have any real amount of reinforcing generally and hardly any penetration.I can do vertical down ok but not up it driving me mad
Welding tips and tricksCan you recommend any good vids
Would my 160 amp inverter run 7018 I can get orelikon 7018s . In the local welding shop
Up date on my vertical welds I got some 7018 rods and there much easier do vertical welds
