Screwdriver
This was as close as I could get.
The area is twice this size with two larger trees cut down on the left.
That’s why they make resin tables out of itBeing walnut it will full of defects
And because they are not cabinet makersThat’s why they make resin tables out of it![]()
What sort of defects are we talking about? Is that typical for British Walnut?
Rounds need to be cut from sealed end well seasoned wood . if you think a six inch thick round will turn nicely you need to realise that the cut ends will have cracks several inches in from the original cuts . Even sealed seasoned cut rounds tend to be re dipped in sealing waxes to stop moisture getting in along the tubular grain cells.It's well worth keeping. English walnut is worth good money, even just as rough sawn planks.
However, unless there's a chainsaw mill, it's not going to be planked.
If you can move the thing whole then do that.
Rounds will not be as valuable. Sure turners will have them but if you plank it, every YouTube watching resin table builder will be keen.
I mean I'd be keen. But you're miles away.
about 4 foot diameter at the ground.
I used a small pan of red candle wax , melted it on an electric pad ( no flames ) then 2 inch paint brushed it on the newly drying cut ends and in places where branches etc had been cut off , two coats on each ends seems to have it sorted .Yeah I have a fair bit of plum cherry out the back, ends dipped in wax etc. It had become infected with something I think because the inside looks for all the world like a starburst of deep red. As if someone dropped a tin of paint. Haven't sliced one open yet but its been a few years now and I think it might be time...
If I can get my hands on some large rounds, I'll probably use a sort of sealing paint because a big round is going to need a lot of wax! If all goes well, I might actually end up with some chainsaw milled planks. Then I just need to decide where to keep them.
the only bit of interest is the dark bit in the middle.... really not worth the effort.
walnut is typically a 200% wastage/splits/defects in the dried product ... so more like 250% from round
Kinda curious how I can waste 200% of it![]()
