Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Oy, easy now, if I can stick two bits of metal together, I'm happy.What do you mean "looked?"
No, sadly it doesnt, but it is stuck together, which is the battle, so I'm happy.That's another candidate for the: It looks better in real life than in the photo, clause.
What were you trying to use before the aluminium rods?No, sadly it doesnt, but it is stuck together, which is the battle, so I'm happy.
So frustrating using the wrong rods, and failing miserably for two hours.
It's all learning and practice, and I get paid to do it.It builds character.
Welding in the rain? Water trapped in the joint, electrodes soaked, gloves soaked, water between the lenses so as you can't see: welding in the rain; Don't do it!
You have wood burner.It was a bit scrap yard challenge.
Find off cuts in the workshop.
10 vertical c / u sections vertical, on the outside, triangular gussets on the inside.
To hold 12 cm x 30cm bits of wood, vertical.
If that makes sense.
Look at their scrap wood pile.
this was in the lake district , a few years ago , absolute nightmare ! at best holes were pumped out and a bucket of gravel was dumped in .
bottom half of pipes were welded before the water filled up your wellies
much preheat needed
was a cowboy outfit that had outbidSo other than getting a welfare unit nothing has changed in the last forty years
Bob
Livin the dream!heres some more rainy day pipe welding . a typical aberdeen autumn day digger is holding shelter from blowing away
its tough at the top
even worse on the bottom View attachment 366955View attachment 366956View attachment 366958View attachment 366958 View attachment 366957
