I also started Tig welding with the intent of fabricating and welding manifolds, exhausts and other car related products, and I understand that the sort of customers that buy these products want to see "Pretty" welding.
Well after 8 months, 12 bottles of Argon and a hell of a lot of metal here is where I'm at with my "Pretty" welding attempts. This is a few scraps from the bin (Stainless pipe, mild plate) thrown together and welded with an R-tech Tig 201, straight amps (No pulse), machine set to 130 controlled via foot pedal, and using a ck9 flex head, free hand with about 6-8 ltrs/m and 10 seconds of post flow.
I used a very slight weave between the lower plate and pipe, and was dipping filler on the up stroke of the weave (Ie dabbing on the pipe more so than the flat). I welded about 1" at a time and worked my way round the pipe so as to blend in the stops and starts. That was with a ck gas saver lens with a no.8 cup.
I try to watch the puddle very closely at the front, and also behind the torch and adjust amperage and travel speed to keep the size of it consistent. I also try to make sure that on my re-starts I fully melt the "tit" left from the previous stop to the same size as the bead before I start moving and adding filler again.
As said arc length, heat control and consistent filler additions are the key things to concentrate on.
I'll just keep practicing though...
Good luck mate![]()
That looks pretty much perfect To me
