I've tried Arc, Mig and Tig, and at present Mig is where I'm most comfortable. I struggled like hell with Arc, but picked up mig fairly quickly. Tig was OK, and I can see having a play with it in a few years, but want to concentrate on Mig for now
i go to work and get paid the shiny stuffdepens what i'm doing. I love playing with the tig and making shiny stuff. sadly that dosent pay the bills
One thing I have noticed is that there seems to be a few comments in various posts saying that MIG is only suitable for thin steel or is slow, I would totally disagree with that.
MIG can be used for welding any thickness steel from 1mm up to and over 150mm + plate, provided that you match the welder to the job which is true for any welding type. As for being slow, MIG is about 4 times faster than any other process and if it isn't then you are definitely doing something wrong.
Cheers
Ed.
Agreed about mig in a production envoironment being king for speed and making a living,I think that it is a matter of choosing the right process for the job, for myself, MIG, is the method of choice if doing general welding in steel and stainless. Depending on the job and using Aluminium or Stainless, then it could be either TIG or MIG, and if thicker Aluminium (8mm+) or Stainless (4mm+) then the MIG would get the preference (again depending on the job).
MMA (stick) would get the preference on welding outside in a strong breeze if however I could set up a wind break then I would pick the MIG first unless there was a lot of mill scale/crap on the metal which couldn't be cleaned off properly in which case it would be back to MMA, as well as if the job was high up in the air. As for Oxy/Acet welding the last time I used it was about 45 years ago in Tech school for doing brazing, as I haven't had a need for it, but it certainly has it's good points but as I said I don't require it . Although I did use it a lot for cutting steel at one stage but now mainly use the plasma.
Cheers
Ed.
It was me saying it is slow am guilty. All I get day in day out is oxy acetylene is out dated and slow compared to mig.granted on long runs of the same material but what I mean was slower than oxy acetylene for restoring and welding cars of different thicknesses I set oa with no 2 jet off I go no messing with wire speed or voltage and with oa I can get almost invisible weld very little clean up. If I use the mig to patch up a sill by the time the mig is setup and the work is cleaned perfectly I could be almost done with oa no clean up just burns away any dirt grime then I would have to grind the mig weld back before painting.I would think people saying that only have experience of hobby welders. my big MIG can blow holes in 10mm without fuss. usually welding 3-15mm on 1.0 or 1.2mm but if there is a load of thick stuff to do out comes the 1.6mm wire and there is no hanging about then. problem is about half an hour later you end up remaking the earth lead after the clamp has melted off
verry true anyone that hasnt used or got proficient with gas welding doesnt know what they are missing especialy doing classic car weldingIt was me saying it is slow am guilty. All I get day in day out is oxy acetylene is out dated and slow compared to mig.granted on long runs of the same material but what I mean was slower than oxy acetylene for restoring and welding cars of different thicknesses I set oa with no 2 jet off I go no messing with wire speed or voltage and with oa I can get almost invisible weld very little clean up. If I use the mig to patch up a sill by the time the mig is setup and the work is cleaned perfectly I could be almost done with oa no clean up just burns away any dirt grime then I would have to grind the mig weld back before painting.
Basically a six inch patch on a sill ready to paint would take some beating oa.
By the way if your earth clamp is self destructing you should upgrade the cable and the clamp, I use a 6m x 2/0 cable and it barely gets warm up to 350A. I was thinking about fitting a 4/0 cable but since I don't have a need to use the 600 amps, I decided to save some dollars. I rarely ever need to go past 280A and that cable is more than adequate, I also use a modified G clamp with a copper pad on both contacts as the work clamp, works well too! Which MIG welder do you use?
Cheers
Ed.
